b7100 kabota
/ b7100 kabota #1
trickfix08
b7100 kabota
ok i have a b7100 kabota i'm working on for a friend and i should have said no but i'm not that smart so i need a wiring diagram because the other guy who helped her just cut and made a mess so i need help LOL
/ b7100 kabota #2
What exactly are you trying to rewire? That machine is pretty simple. I might be able help.
Brian
/ b7100 kabota #3
If you PM me with your email address I can send you a PDF of the wiring diagram.
/ b7100 kabota
Brian
the glowplugs it looks simple but i just need a diagram i work on so much junk but not a lot of tractors
/ b7100 kabota #5
The wire for the glow plugs just comes from the ignition switch, the terminal that has power when you turn the key to the left, it goes from the switch to the glow plug indicator, the little coil on the dash, then to the glow plugs, I believe it is a black wire with a white stripe.
Brian
/ b7100 kabota
did that work
/ b7100 kabota
thanks a lot but i think i going to need a diagram because the guy that had worked on it befor me only new how to use wire cutters HAHA
/ b7100 kabota
and you will have to excuse me i'm not good with this computer at all LOL
/ b7100 kabota
i'm not very good with this computer stuff but that would be a big help you can send it to trickfix@aol.com and thanks
/ b7100 kabota #10
I'm out of town this weekend, when I get home I'll have to look and see if I have a diagram I can scan for you.
Brian
2018 CATERPILLAR 299D2 SKID STEER (A65053)
2018 CATERPILLAR...
2017 GENIE S-40 TELESCOPIC BOOM LIFT (A65053)
2017 GENIE S-40...
1987 Polar 307 SS 3 Comp SS Insulated T/A Chemical Tanker Trailer (A64194)
1987 Polar 307 SS...
2022 EZ-GO ELITE...
1000 GALLON FLAT BOTTOM POLY TANK (A64278)
1000 GALLON FLAT...
2017 Ford Escape SUV (A64557)
2017 Ford Escape...
