b7100 hydraulic pressure
   / b7100 hydraulic pressure #1
rodgemx125
i have a 1983 b7100. the loader and 3PT linkage seem to work ok but i have just bought a log splitter and it is strugling to split any wood.
Is there a presure adjustment at all?
Any help would be apreciated.
   / b7100 hydraulic pressure #2
It is possible to adjust your tractor hydraulic pressure ... BUT before you make any changes, it would be a great idea to check your existing pressure.
Your problem with the splitter could be cylinder size... You need to start with knowing your delivery pressure... KennyV
thanks, where would the adjustment be? is it adjusted by thicker shims?
should i be looking for aroung 2000psi?
thanks
   / b7100 hydraulic pressure #4
You need to get the spec for your tractor for the correct pressure, and yes it is shim adjusted at the relief valve for the pump. KennyV.
Someone may come on with the correct pressure setting for the B7100....
   / b7100 hydraulic pressure #5
Whats the recommended flow rate for your splitter as compared to what the B7100 will put out?:D
   / b7100 hydraulic pressure #6
Keep in mind you have only about a 3 gpm flow on a B7100
2017 GENIE GS-2646 (A52472)
2017 GENIE GS-2646...
Ingersol Rand 175 Air Compressor (A50774)
Ingersol Rand 175...
White 255 Disc (A50774)
White 255 Disc...
1992 Effer 7600 2S Knuckleboom (A51691)
1992 Effer 7600 2S...
2016 Nissan Altima Sedan (A50324)
2016 Nissan Altima...
