B7100 Engine Serial Number
   / B7100 Engine Serial Number #1
gapaxton
Where is my engine serial number? I have a B7100 HST. Others have suggested that it is stamped on to the block behind the fuel injection pump. My fuel injection pump appears to drop into the block casting, not bolt on to the side of the block. I need a new crankshaft, rod, etc. but I can't order parts until I find this elusive serial number.
Where do I get the parts?
Maybe it would be less trouble to find a used engine.
   / B7100 Engine Serial Number #2
If you would have filled out PART of your profile... like where you are located... there is a chance that someone near you may have what you are needing...
But being as you could be anyplace in the world here is the only salvage yard locater, that I have, that might cover where you may be...
Antique Tractor Parts Sources | Antique Tractor parts resources for Antique Tractors in the United States and other countries
2024 CATERPILLAR 259D3 SKID STEER (A60429)
2024 CATERPILLAR...
2009 Peterbilt 384 Semi (A59814)
2009 Peterbilt 384...
1976 East Dump Trailer (A59814)
1976 East Dump...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
MASSAGE CHAIR (A58214)
Case 950 8 Row Air Planter (A56438)
Case 950 8 Row Air...
