B7100 Block Heater
   / B7100 Block Heater #1
aeblank
Veteran Member
Cadillac, MI
Kubota L3940
So my brother has a B7100, and he's trying to put in a block heater.
Dealer sold him one, but the adapter is too large for the freeze plug hole.
Current thought is to machine down the in-hand adapter to fit the hole.
Assuming a .001 to .0015 press fit, but does anyone know the dimensions of the *real* adapter? There is a taper on it.
Also, the depth that it'll go in to the block, appears to be too far. In machining, we can limit the depth the adapter can go in....
All dealers say "sorry, discontinued". Is there any other (non-custom) solution? Buy just the *correct* adapter?
Let me know your thoughts, and I'll pass it along.
Thanks!
   / B7100 Block Heater #2
Not sure about that heater but make sure that the heating element clears the block when it's fully inserted no matter what you do. You also might look at magnetic or hose heaters if the block heater doesn't work.
Sent from my iPhone using TractorByNet
2005 Caterpillar 430D 4x4 Extendahoe Backhoe Loader (A51691)
2005 Caterpillar...
(INOP) NEW HOLLAND L328 WHEELED SKID STEER (A51242)
(INOP) NEW HOLLAND...
2017 DRAGON 130 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 DRAGON 130...
2025 K3325G UNUSED Double Garage Steel Barn (A53117)
2025 K3325G UNUSED...
2015 JOHN DEERE 624K WHEEL LOADER (A51406)
2015 JOHN DEERE...
47 ft. Portable Transfer Dock (A53117)
47 ft. Portable...
