B7000 dynamo
   / B7000 dynamo
Good morning. Found the alternator on the fan shaft. Thought it was a water pump until I saw the wire coming out of it. So I bought a new battery and it starts 1st time after preheating the glow plugs. Thanks so much for your help.
Next problem is the oil leak from around the pto shaft. On orange tractor talk I followed a thread which lead to the Kubota part number and ordered one from local dealer. It is too small! The shaft measures 35mm dia. Have you any idea where I can order the correct seal?
Regards, David
   / B7000 dynamo #12
I've found this:
OEM -35488 Seal Oil B71 PTO (35x48x9mm) | Stavros Savva & Son Ltd
Seal PTO shaft original Kubota - TP195 - TracPartz
But if any of those works, I would sugest go to an hydraulic shop with the old one. Maybe they have one. Although the lip it has makes it a bit "special". It's there so you can remove it without taking the PTO plate apart.
Last resource, you can get a regular seal 35x48x9 without the lip. It will work just fine, but you don't have the lip to remove it without pulling the plate around the PTO shaft out.
   / B7000 dynamo
Went to my local Kubota dealer with part number. Would not supply it for an import from China so ordered it from Stavros. Thanks for help. I hope the bearing is ok.
Dump Truck Body with Tarp System (A55851)
Dump Truck Body...
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
2020 CATERPILLAR 323 EXCAVATOR (A52709)
2020 CATERPILLAR...
1969 Lincoln Continental Mark III (A56859)
1969 Lincoln...
PALLET OF LIGHT BULBS & PIPE VICE STAND (A52708)
PALLET OF LIGHT...
2019 Caterpillar 289D3 Compact Track Loader Skid Steer (A55973)
2019 Caterpillar...
