B6200 used. What's a fair $?
   / B6200 used. What's a fair $? #1
THYGESON1
B6200 used. What\'s a fair $?
I'm looking at a used B6200 4WD for about $4500. It looks garage kept and has about 600 hrs. Does anyone think $4500 is a fair price?
Thanks.
   / B6200 used. What's a fair $? #2
Re: B6200 used. What\'s a fair $?
I'm assuming that it is an '80s vintage Kubota that is in the B7200/B8200/B9200 series, which was replaced by the B1550/B1750/B2150 series.
Without knowing the specs on it and what equipment comes with it, it is difficult to speculate about price. But in general I'd say that $4500 is a fair price for a 600 hour 4wd Kubota in good shape. If it is a hydrostatic model with power steering then it would be an even better price.
What do you intend to do with it? If it is a gear drive model I doubt that it has a live PTO thus mowing with a 3-point mower might be a problem.
Hope this "little bit" of information helps.
Kelvin
   / B6200 used. What's a fair $? #3
Kubota B6200DT 4WD, 12.5 PTO HP, 1179 lbs., Mfr. 1983-95, Last Fac. List $8930.
Low/Avg/High - Auction Prices
$3150/3300/3500 w/o implements
The B6200 is gear driven, and the owner says it has a live pto. Along with a 60" belly mower, there is a front blade w/ hydraulics and a sims cab. I hope $4500 was okay, 'cause I bought it today. Runs great, looks great, has turf tires.
Thanks for the info. Tige
Thanks for the info. The B6200 has a 60" belly mower and a front blade. It also has a SIMS cab w/ perfect canvas. I hope that may have dragged the value up a bit, because I bought it today for 4500. Thanks again - Tige
   / B6200 used. What's a fair $? #6
I don't think that you got a bad deal, especially considering how the tractor was equipped. Unless there is something wrong with the tractor, I think that you'll be happy with it.
As far as the live PTO goes, I still don't think that you have one. At least I have not seen any compact gear-drive Kubota (or any brand for that matter) that has live PTO. Of course the lack of live PTO is only problem if you need to change gears and/or direction while using PTO driven equipment (such as a rototiller or rear mower).
THe B6200 probably does have a built in "over-running" PTO clutch. This prevents the momentum of the PTO driven equipment from pushing the tractor around after the clutch is pressed. This may have been the PTO feature that the previous owner was thinking about when they said the tractor had a live PTO.
Congratulations on your new Kubota!
Kelvin
E-Z Trail 680 Head Cart (A50514)
E-Z Trail 680 Head...
2000 Genie S-60 60ft Articulating Boom Lift (A50322)
2000 Genie S-60...
2002 New Holland TN75S 4X4 Loader Tractor (A51243)
2002 New Holland...
2020 JOHN DEERE 333G SKID STEER (A51242)
2020 JOHN DEERE...
2019 Kenworth T880 T/A Wet Kit Day Cab Truck Tractor (A50323)
2019 Kenworth T880...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
