b6200 kubota puking oil out of breather plug ?
   / b6200 kubota puking oil out of breather plug ? #1
b7200hsd
wytheville, va
b7200 kubota
welp , friend of mine has a b6200 kubota that we just fixed the control valve on( replaced the relief valve assembly) now its puking oil after its ran for a few minutes. the oil comes out of the breather tube. anyone have any suggestions?
   / b6200 kubota puking oil out of breather plug ? #2
If the fluid was at the correct level before you started, then I think you are sucking in air and that combination increases the volume and the excess fluid flows out the vent or fill cap.
yes the fluid level is correct, guess i wasnt thinking hard enough about this , realize now im having a cavitation problem , ive probably got a blown oring on the control valve or an air leak therabouts . thanks for your input.
5x7 DK Aluminum Tilt Trailer (A51572)
5x7 DK Aluminum...
UNUSED FUTURE BD43 HYD BACKHOE ATTACHMENT (A51248)
UNUSED FUTURE BD43...
UNUSED FUTURE PC711 - 71" HYD PLATE COMPACTOR (A51248)
UNUSED FUTURE...
2003 FREIGHTLINER FL80 DUMP TRUCK (A51406)
2003 FREIGHTLINER...
Kubota RTV500 (A47384)
UNUSED HURRICANE 10' WROUGHT IRON SITE FENCE (A51248)
UNUSED HURRICANE...
