b6200 kubota puking oil out of breather plug ?
   / b6200 kubota puking oil out of breather plug ? #1
b7200hsd
wytheville, va
b7200 kubota
welp , friend of mine has a b6200 kubota that we just fixed the control valve on( replaced the relief valve assembly) now its puking oil after its ran for a few minutes. the oil comes out of the breather tube. anyone have any suggestions?
   / b6200 kubota puking oil out of breather plug ? #2
If the fluid was at the correct level before you started, then I think you are sucking in air and that combination increases the volume and the excess fluid flows out the vent or fill cap.
yes the fluid level is correct, guess i wasnt thinking hard enough about this , realize now im having a cavitation problem , ive probably got a blown oring on the control valve or an air leak therabouts . thanks for your input.
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A53472)
2014 Doyle Dry...
2015 JLG Triple-L Flatbed T/A Trailer (A50324)
2015 JLG Triple-L...
2000 FORD F450 SUPER DUTY SINGLE CAB FLATBED TRUCK (A51406)
2000 FORD F450...
New/Unused 7ft 10 Drawer Work Bench (A51573)
New/Unused 7ft 10...
John Deere (A50322)
John Deere (A50322)
