B6200 hazard lights not working
/ B6200 hazard lights not working #1
lanschuetz
Lancaster, PA
Kubota B6200
Greetings folks!
Just bought my first honest-to-God tractor, a Kubotar B6200 with MMM. Cut about an hour off my modest 2 acre lot cutting. Diesel fuel gage not exactly accurate (never goes to full) but that's OK - it's not that far back to the house to refill. All lights work with the exception of the hazard lights. I think those might be important :) There is no voltage at the sockets and no "blinker" noise in the dash, so I'm guessing it's either a bad switch, bad (missing) fuse or bad flasher.
I don't yet have a manual, so need some guidance on how to get to the important bits. The little section of dash that holds the flasher switch has 2 screws in it. Removing those seems to accomplish nothing. Assuming that I'm in the right place, how do I get in there and look?
Thanks to all with way more wisdom than I in these matters.
/ B6200 hazard lights not working #2
Use a test lamp.. look for power at the blinker module. and the switch.. and fuse panel. heck.. pull all fuses and see if yuo have a bad one.
( follow the volts.. )
Soundguy
Soundguy
All good advice, but can't get to anywhere I need to test them. That is to say I have battery power going under the dash, but can't get under the dash to go further :)
PS: my other ID is audioguy - FOH engineering for fun and absolutely no profit.
/ B6200 hazard lights not working #4
I also do plenty of FOH, and mines less and less fun each day.. though is sufficiently profitable...
Soundguy
/ B6200 hazard lights not working #5
Cant you pull that dash cowling off.. someone put it together.. it's got to come off.
Do you have any fuses under the hood section? My NH does..
Soundguy
Soundguy
The entire cowl wraps around behind the fuel tank, with literally dozens
of screens. However, it won't come off unless the little sections do -
which puts me back to square one :)
Solesbee Hydraulic Thumb (A61166)
Solesbee Hydraulic...
LMC 2-Row Planter BYJ-2F  Stainless Steel Fertilizer Boxes, Ground-Driven (A61307)
LMC 2-Row Planter...
2001 FORD F-750 SUPER DUTY (INOPERABLE) (A58214)
2001 FORD F-750...
2012 BMW 328i Coupe (A61569)
2012 BMW 328i...
2010 FORD F-150 XL CREW CAB TRUCK (A62130)
2010 FORD F-150 XL...
2019 Chevrolet Tahoe 4x4 SUV (A61569)
2019 Chevrolet...
