B6200 Does not want to start
   / B6200 Does not want to start #1
zoubala
Val des Monts, QC, Canada
Kubota B6200D
Hi
I just purchased a B6200 Kubota and it is so hard to start. The first time it started, we worked at it for an hour and had to boost it with fully charged batteries. I did bleed the fuel line and after a while it started. I turned it off and started it again no problem. Today, no go, it drained the battery and even with a boost forget it.* I get smoke coming out of the muffler but that is it. There is decompression nob but I do not know how to utilize it.
Help
ok today i changed the oil, emptied the fuel tank and put new diesel and a new battery. The glow plugs worked fine and I left them on for at least 45 seconds and it started. everything is fine I guess. Soon It will be time to build a fel on it.
   / B6200 Does not want to start #3
You problem was almost certainly the battery. You should only need to turn your glow plugs on for 3-5 seconds to make a difference.
(INOPERABLE) GEHL 8K TELEHANDLER (A58216)
(INOPERABLE) GEHL...
2002 EZ-GO TXT Golf Cart (A57453)
2002 EZ-GO TXT...
IRanch High End Mini Golf Cart (A57149)
IRanch High End...
2019 Ford F150 XL (A57148)
2019 Ford F150 XL...
KUBOTA SSV65 OPEN STATION CAB (A52706)
KUBOTA SSV65 OPEN...
2380 (A58376)
2380 (A58376)
