B6100HST 4x4
   / B6100HST 4x4 #1
bpicard
Houston, TX
L2350DT
I just bought the little tractor and it runs nicely. There is one problem, however, with the front axle pivot assembly. It appears to me that the differential/axle assembly should only rock side to side, however, when the steering wheel is turned, the differential/axle assembly appears to move backward on the pivot pin nearly 3/8" or possibly more. It seems like a bushing or two is missing, perhaps worn out to the point where nothing is left.
Does anyone have an exploded parts view of the assembly?
Are any of you familiar with the problem?
As the whole axle and 4x4 diff' moves backward, is it possible that the front wheel drive line is damaged from the movement?
Thanks in advance.
Brian.
   / B6100HST 4x4
The movement is closer to 1/4". I could really use some help on this. An exploded parts diagram would be great.
Thanks.
Brian.
   / B6100HST 4x4 #3
I have the gear drive model and I don't recall any movement like you mention. If I understand you correctly, these pictures may help you out. As for harming any of the driveline, I doubt it because there are u-joints and a splined shaft inside that boot attached to the front differential.
   / B6100HST 4x4
Mike,
Thanks for the quick reply and parts diagram. I was told by my local Kubota guy that there are some shims that have likely worn. I'll need to drop the differential to replace--I don't know what's involved with that but here goes.
Thanks again.
Brian.
2013 FORD F-150 XL EXTENDED CAB TRUCK (A51406)
2013 FORD F-150 XL...
2025 New/Unused Wolverine Pallet Fork Frame with Forks (A51573)
2025 New/Unused...
2004 International 4300 Box Truck, VIN # 1HTMMAAMX4H667102 (A51572)
2004 International...
2018 COLOMBO TM LOT NUMBER 184 (A53084)
2018 COLOMBO TM...
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
