B6100 fan belt replacement
   / B6100 fan belt replacement #11
I think the belt tensioner tightens from the side. If you take off the side screen you should be able to reach it.
   / B6100 fan belt replacement #12
Just be glad it’s not a B20 with a front crankshaft driven hydraulic pump. Lots of wrenching to replace a fan belt.
Hi all,
Quick update: the fan belt is replaced, dynamo bearings were aok, and took about 2 hours going s l o w l y. I didn't have to disconnect the top radiator hose, but all the other steps were required.
Much thanks to all who chimed in with tips and especially the helpful video (thanks Thomas!) of another Kubota owner walking thru the sequence.
Cheers! :drink:
   / B6100 fan belt replacement #14
Want to know how to get belt off on a B6100d with front mount hydraulic pump.
   / B6100 fan belt replacement #15
Thata easy..cut it off..getting the new one back on is the issue.
   / B6100 fan belt replacement #16
John Deere Hx14 14' Mower (A56469)
John Deere Hx14...
Giyi 48" Mini Excavator Root Rake (A56469)
Giyi 48" Mini...
(3) 20' CHAINS, (2) RATCHET BINDERS (A57192)
(3) 20' CHAINS...
KBH Mule Boy (A53317)
UNUSED 1RANCH 1RET13 HIGH END ELECTRIC TRICYCLE (A57192)
UNUSED 1RANCH...
UNUSED RAYTREE RMSG29 29" HYD STUMP GRINDER (A57193)
UNUSED RAYTREE...
