Oil & Fuel B6000e Kubota Tractor
/ B6000e Kubota Tractor #1
CindyS1015
Lemoore, CA
B6000e
Does anyone know where a video on how to change the oil on a B6000e Kubota Tractor
It's was bought in 1972 or 1977 I have the manual.
/ B6000e Kubota Tractor #2
Read the manual, pull the engine drain plug/s, drain oil, remove oil strainer, clean with solvent or gasoline (carefully if using flammable liquids) and replace, replace drain plug/s, fill with oil to correct level on dip stick.
Edit: No cartridge filter on this engine as noted in later post.
Are you doing the transmission fluids as well?
/ B6000e Kubota Tractor #3
Those old tractors were pretty easy to service. In CA I would use 15W40.
/ B6000e Kubota Tractor #4
From a different Forum ...
Jon De Rusha I recently bought a '70s Kubota B6000E. In the process of updating fluids, filters, etc., I learned that a new oil filter cost $107.15. Can the old filter be cleaned and re-installed? If so, will I need to replace any gaskets? How often does the oil filter need to be replaced? Any information about this matter will be greatly appreciated.
jm. Jon Afraid some unknowing parts guy has let you astray. If you were to try and drain the engine oil you will find as you remove the oil plug attached will be a long brass strainer. That serves as the oil filter. No need to replace this just take light solvent like kerosene or parts washer fluid like varsol and wash it clean.
Reinstall and you are ready to go. Only replace if towrn or clapsed beyond use.. Hope this helps Jerry.
2012 International (A59230)
2012 International...
2024 DODGE RAM 2500 HEAVY DUTY PICKUP TRUCK 4x4 (A59912)
2024 DODGE RAM...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
2015 John Deere 8270R (A64119)
2015 John Deere...
2005 Freightliner Tropi-cal T396 39ft. Class A Motorhome (A61574)
2005 Freightliner...
