B6000 rear wheel spread
   / B6000 rear wheel spread #1
cappys tractor
Cape Cod, Ma
B6000 4WD
I saw a photo of a B6000 with the rear wheels put on 'inside out' so to speak.
After looking at my axle, it does appear that you could take the wheels off, and put them on inside out to gain maybe an inch or two of width.
Is this worth it? (the schrader valves would be in the inside though)
   / B6000 rear wheel spread #2
Depends on your needs. I've had a B7100 off and on since the late '70's always with a FEL so I wouldn't have it any other way for the increased stability. If you are on flat ground and need the clearance for gates and narrow openings, probably not. But I always felt better with as wide as possible because of the FEL and hilly terrain.
1977 Allis Chalmers 7060 Tractor (A50514)
1977 Allis...
1997 John Deere 690 Elc Excavator (A50514)
1997 John Deere...
2025 Swict 78in Bucket Skid Steer Attachment (A50322)
2025 Swict 78in...
KUBOTA M7040 TRACTOR (A51406)
KUBOTA M7040...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51406)
KNOW BEFORE YOU...
CASE 850M WT CRAWLER DOZER (A51242)
CASE 850M WT...
