B6000 rear wheel spread
   / B6000 rear wheel spread #1
cappys tractor
Bronze Member
Cape Cod, Ma
B6000 4WD
I saw a photo of a B6000 with the rear wheels put on 'inside out' so to speak.
After looking at my axle, it does appear that you could take the wheels off, and put them on inside out to gain maybe an inch or two of width.
Is this worth it? (the schrader valves would be in the inside though)
   / B6000 rear wheel spread #2
Depends on your needs. I've had a B7100 off and on since the late '70's always with a FEL so I wouldn't have it any other way for the increased stability. If you are on flat ground and need the clearance for gates and narrow openings, probably not. But I always felt better with as wide as possible because of the FEL and hilly terrain.
2022 FREIGHTLINER M2 24FT BOX TRUCK (A51222)
2022 FREIGHTLINER...
PALLET OF FUSION EQUIPMENT (A50854)
PALLET OF FUSION...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
Genie GTH-644 (A50490)
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2021 FREIGHTLINER...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
