B3350 Wity 60" Rotaty Cutter
   / B3350 Wity 60" Rotaty Cutter #11
Interesting about your comment about B3350 reputation. I was unawares.
Anything more descriptive?
SDT
DPF regeneration failures. There are several topics here, and on other forums- also some recent failures. I guess it's possible the current problems are older machines just now being sold as new, but if you read the actions dealers have taken to "fix" the regeneration failures it seems pretty obvious that Kubota has no idea what the problem is.
Don't take my word for it. Do your due diligence though, and good luck with whatever you decide to go with.
   / B3350 Wity 60" Rotaty Cutter #12
Just as a reference point, I'm running a Landpride RCR1860 on my B7800. The RCR1860 is 599 lbs. B7800 has an FEL. I can feel the weight. RCR1860 is new to me/this tractor, but so far it's working well. I definitely can see where it's best to travel around with the tailwheel on the ground: my previous 5-footer, a Rankin light duty, was a lot lighter and I could hold it's tailwheel off the ground without much concern (and given that it didn't have a floating top link it would, in fact, tend to find itself raised off the ground quite a bit- I have a lot of undulating ground).
2019 Tico Yard Spotter Truck - Cummins Diesel, Allison Auto, Hydraulic Air Fifth Wheel, Cab w AC (A52128)
2019 Tico Yard...
Komatsu D39PX-24 Crawler Tractor Dozer (A49346)
Komatsu D39PX-24...
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
VERMEER 605F ROUND HAY BALER (A51243)
VERMEER 605F ROUND...
Quick Attach Pallet Forks (A47384)
Quick Attach...
