B3350 Regen - Any Updated Knowledge on Current Model
   / B3350 Regen - Any Updated Knowledge on Current Model #1
welyell
Vashon, WA
Kubota MX5800
Going through the Kubota website, I really liked the specs on the B3350 - BUT - read many reports on DPF regen issues. Reports I've read were as new as late 2017. Has anyone here purchased a new (2018) B3350? Any knowledge on if the software updates Kubota has sent out have actually fixed the issue on prior year models?
   / B3350 Regen - Any Updated Knowledge on Current Model #2
We have done a couple of the latest updates on tractors with symptoms and haven’t gotten any feedback. Which generally means they are fixed and working properly.
   / B3350 Regen - Any Updated Knowledge on Current Model #3
I bought a new B3350 about 8 weeks ago.
Among other things, I'm a long time design engineer and mechanic. Before buying, I researched thoroughly.
The B3350 and associated F series professional front mount mowers using the same engine are the only Kubota farm/homeowner machines that use mechanical injection rather than the more modern common rail systems while also adhering to the nonsensical federale TIER IV regulations.
Accordingly, the regeneration algorithm is completely different for the B3350 engine than for other larger Kubota common rail injected engines.
Yes, Kubota stubbed their toe badly with the B3350 and associated machines, indeed, uncharacteristically so.
That said, it appears that most (all?) of the regeneration issues associated with the B3350 and related machines have been resolved.
That also said, being an old design engineer, I would be very surprised if Kubota was not now redesigning the small 4 cylinder direct injected diesel engine with common rail (more costly) technology.
Also, being an old MBA/marketing type of guy, it would not surprise me if Kubota simply decides to abandon this small market segment in order to save the development costs for the sake of such nonsensical TIER IV nonsense.
Stay tuned.
SDT
2003 Big Tex 10PI...
2016 FREIGHTLINER  CASCADIA (INOPERABLE) (A58214)
2016 FREIGHTLINER...
JOHN DEERE HAY CUTTER (A58216)
JOHN DEERE HAY...
2012 Ford F-550 4x4 Chipper Truck (A55973)
2012 Ford F-550...
2017 John Deere 5090GN (A53317)
2017 John Deere...
TARTER CATTLE MASTER HEAD GATE (A58374)
TARTER CATTLE...
