B3350 and diesel particulate filter
/ B3350 and diesel particulate filter #21
Ok. Taking that model off the table is the DPF reliable in any of their other models? Looking at a 2016 L3301 that has the same type filter/regeneration system as well.
Limited search has not resulted in the same level of red flags so was the issue more specific to the B3350 or the regeneration process itself?
They're very different.
The B3350 used mechanical injection. The L3301 is EFI. EFI allows better control of the regen. The 3350 has a small turbo engine. The L3301 has a larger naturally aspirated engine. Turbos are heat powered superchargers. They take heat from the exhaust to power the compressor turbine. That makes the post-turbo exhaust less hot so the DPF has a harder time maintaining temperature during regen. Many of the people with regen problems on the 3350 were operating in colder temperatures.
I'd stay away.
I'd stay away.
But it would be considered “safe” to pursue the 3301?
Private party seller, 400 hours, has not had regen issues.
/ B3350 and diesel particulate filter #23
You should be ok. There are a lot of those out there, including mine, with no problems.
That’s only about 65 hours per year.
My 2018 has twice the hours, and I consider it to be a new tractor.
/ B3350 and diesel particulate filter #24
I'm still confused on why you want a different tractor from the little Boomer? Is it just desire for something new? Do you just want a regen type tractor? Some folks do.
It's your decision of course. And I'm not being critical; but I am perplexed.
rScotty
/ B3350 and diesel particulate filter #25
He mentioned it before, he wants to replace his TC24 with something HST with a little more power.
/ B3350 and diesel particulate filter #26
The ZD1511 had Regen issues as well. I believe the zd1511 and B3350 share the same mechanically injected engines. The ZD issues I have read about were summertime wide open operation, so the operator error lie doesn't hold water.
On the B3350 Kubota threw parts and computer updates at the problem, and it was clear they had no idea how to fix them.
None of the other DPF equipped machines had problems like these two, including the L01 series and L60 series. My L4060 had been flawless, regenerating while operating every 50h average.
rScotty
Keeping my TC 35d and selling my TC 24d. Want more Hp, and hst.
/ B3350 and diesel particulate filter #28
Not pushing for the B3350,but member sandyc from Maine had his B3350 cab fixed.
He has since traded to a BX model
Good Luck!
/ B3350 and diesel particulate filter #29
I bought my B2650 in December 2019. At the time I was also looking at the B3350. My local dealer didn't carry them and wouldn't sell them, "until Kubota fixed the problem." So, if it was built in 2019 or earlier, expect problems.
/ B3350 and diesel particulate filter #30
Was looking at a used B3350 as an upgrade to a smaller tractor I currently own. Was excited about the somewhat nimble size and power these tractors seem to have.
However I am now very Nervous to proceed after reading about all the diesel filter regeneration problems. Nobody has time to be bringing such an important tool back and forth to the dealer and meanwhile not getting any work done.
Do all the 3350s have this problem in one form or another?
Is it a certain percent if the units that have this problem?
Does anyone own one and actually been satisfied with it and not had this problem or is the whole process of regeneration painful even when it works?
Has kubota provided any solutions?
How could I possibly know if the model I’m looking at is one of the “problem children”?
Appreciate any input. This model is giving me mixed emotions instead of excitement about an upgrade. ☹️
If you live in a area that is below 5,000’ elevation these work good closer to 2,500’ they run hot enough to work
But you have to run it at full throttle
But if you have a trailer and can do with out your tractor while Kubota repairs it then it’s all good
The first year 2013 is the worse year newer ones can have the DPF bypassed
The problem is not just Kubota all compact tractors have problems with regen some more than others my neighbors have MF and have much fewer problems
If I had it to do over I would not have bought this tractor but there wasn’t a lot of information about them
/ B3350 and diesel particulate filter #31
If I was looking for another tractor it would have fuel injection similar to this, but that's just me.
each to his own....
/ B3350 and diesel particulate filter #32
I'm going to offer some advice different from the others. RUN, don't walk from this tractor!
/ B3350 and diesel particulate filter #33
Check out this video from Messick's on the B3350. Neil Messick acknowledges that the model had "some issues" with the exhaust system, but he bought one for himself because he got a good price on it exactly for that reason.
Also, it helps that he owns a 30,000 sq ft (now 60,000 sq ft) shop that he can bring the thing to on a moment's notice when it has problems. (He didn't mention that, that's my two cents!)
EDIT: Actually, he did mention that. I went on and watched the entire video, past where he mentions the B3350 issues, and he says - paraphrasing - that the folks who work there often buy distressed tractors that the general consumer stays away from due to well-known issues. So kudos to him for telling it basically like it is!
Ok. I passed on the 3350 and did buy the L3301 from a private party.
Looking forward to familiarizing myself with this strange new orange machine.
Appreciate everyone’s input and honesty.
/ B3350 and diesel particulate filter #35
You'll quite enjoy the L3301 I suspect, it's quite the well built machine.
/ B3350 and diesel particulate filter #36
We’ve owned 6 kubota tractors, with one exception they have been reliable, economical machines. The exception was a B3350. The tractor was fuel efficient, nimble, and powerful for a compact tractor. The cab, hydraulics, control arrangement, were capable and easy to use. Just a shame that a machine with such admirable attributes was so unreliable that those attributes were unavailable. A machine that can’t be trusted is a liability and not an asset!
/ B3350 and diesel particulate filter #37
Both my older M9's are very fuel efficient and I'm glad considering the price of off road diesel today.
/ B3350 and diesel particulate filter #38
I like my Yanmar YT235C as when it regens
I just keep on working no need to stop
willy
/ B3350 and diesel particulate filter #39
I have 282h on my TYM with a mechanical Cummins A-series license derived engine with NO regen requests ever to date. It does it passivley as you keep it working if you're above 1800-2000rpms.
/ B3350 and diesel particulate filter #40
I have just shy of 300 hours on my l3901 I had 1 issue the seat switch shorted out fixed under warranty. I have had 4 regen cycles. It’s a good machine if you can get it for the right price
UNUSED FUTURE EXCAVATOR COUPLER (A60432)
UNUSED FUTURE...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A56438)
Kuhns AE10 Small...
2013 Land Rover Range Rover Sport 4X4 SUV (A55853)
2013 Land Rover...
CONIBEAR EQ CO HYD SEED SPREADER (A60430)
CONIBEAR EQ CO HYD...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A61306)
2016 RAM 5500...
240156 (A56859)
240156 (A56859)
