B3200HSD 12VDC Accessory Outlet and Warning Light Custom Install
   / B3200HSD 12VDC Accessory Outlet and Warning Light Custom Install #1
Birdman1970
Northern, VT
Kubota B3200HSD
One other customization I did to my tractor is to add a warning light.
I picked up this warning light from Tractor Supply Company. It is magnetic on the bottom and uses a standard 12VDC cigarette lighter plug/acc plug for power.
I mounted the 12VDC ACC plug in the rear of the right plastic fender cover of my B3200HSD so the light could be mounted in the middle of my ROPs via its magnetic backing. I got it at a local land/air shop that had these for motorcycle use, so they are perfect for all-weather applications.
I also took a picture of where I sourced the power (with the fuse) on the left hand side of my tractor.
   / B3200HSD 12VDC Accessory Outlet and Warning Light Custom Install #2
Nice job. :thumbsup:
How does the light hold up upside-down?
   / B3200HSD 12VDC Accessory Outlet and Warning Light Custom Install #3
neat job :thumbsup:
Thanks for the compliment. The back of the light is actually magnetic. I'm a little concerned that it may bounce off due to vibrations when working the tractor, but I've ran it around the yard over some pretty good potholes and it held well.
As a 'safetey net' I put a couple black tie wraps around the cord and the ROPs just in case ;)
   / B3200HSD 12VDC Accessory Outlet and Warning Light Custom Install #6
Oh, OK. That's a good idea putting tie wraps around the cord. I don't know if I would trust the magnets on the light I have upside-down...
2009 MINI Cooper Coupe (A50324)
2009 MINI Cooper...
2015 CATERPILLAR 303.5E2 CR EXCAVATOR (A51242)
2015 CATERPILLAR...
40' CONTAINER (A51244)
2016 Timpte Hopper Bottom (A50514)
2016 Timpte Hopper...
PENDING SELLER CONFIRMATIONS (A52141)
PENDING SELLER...
2019 Ford F-250 XL (A50120)
2019 Ford F-250 XL...
