3-Point Hitch B3200 Mower Match
/ B3200 Mower Match #1
sjm1580
Southwest Florida
Kubota L5740HST, Takeuchi TL220, Kubota zd221
I have a B3200 TLB and need a bush hog mower to help get a 10 acre parcel under control. What size mower would be recommended for this size machine?
Thanks for any recommendations.
Steve
/ B3200 Mower Match #2
I use a Woods Brush Bull 48" rotary cutter. I normally cut with fel on. I have used it with out the fel and it is fairly balanced. I had a smaller LandPride cutter that I used with a BX25 and a b2620. I think the Woods is a little heavier and easier to hook up than the LP was. :2cents:
/ B3200 Mower Match
Do you think going to a 60" would be possible or would it be oversized?
/ B3200 Mower Match #4
I also have a B3200 and it pulls my Landpride 5' cutter just fine. I always cut with FEL on.
/ B3200 Mower Match #5
You should fine with a 60" cutter. My 2620 handles a 54" Woods just fine.
Will
/ B3200 Mower Match #6
I just bought a 60" Woods Brush Bull for my B3200 a couple months ago. Works great, not too big. It's just a little wider than the rear tires so I can cover my tracks. Just remember to leave the FEL on to counterbalance the weight.
2012 Gillig G27B102N4 Low Floor 32+54 Low Floor Passenger Bus (A66736)
2012 Gillig...
LEEBOY 8515B PAVER (A67714)
LEEBOY 8515B PAVER...
2018 CHEVROLET TAHOE (A66091)
2018 CHEVROLET...
Stertil Koni 18000lbs 4-Post Auto Lift (A61572)
Stertil Koni...
2017 Ford F-350 Knapheide Service Truck (A66736)
2017 Ford F-350...
Giyi Mini Excavator Attachment Set (A64912)
Giyi Mini...
