Oil & Fuel B3200 kubota hst filter and hydraulic filter
   / B3200 kubota hst filter and hydraulic filter #12
Yes there is.
OK where?
There is not one on mine and the parts manual does not show one. I know the operators manual mentions one but it is wrong!
   / B3200 kubota hst filter and hydraulic filter #13
OK where?
Page 59 Operators Manual. With the added frame in the way it is a bear to get it out. Don't force it, just bend the screen as little as possible. The end of the suction line has two O-rings that can be a problem. The second time I did this it was easier.
Did you remove the bolt to check the screen and found no screen. Or don't recognize the location?
   / B3200 kubota hst filter and hydraulic filter #14
Checked my printed parts manual and could not find it. Looked on the new online version and found it. I am headed this morning to see on the machine. Learn something every day.:ashamed::cool2:
   / B3200 kubota hst filter and hydraulic filter #15
One of the reasons I like to know if the person giving me an answer actually owns the specific machine in question or if the know a man that knows a man that's grand dad used to see one next door a lot. Also there are a lot of responders of even DIFFERENT brands giving some almost positive answers regarding specific machines. I've never owned an other brands but Kubota and I've owned several of them and have had people pull an old answer I gave when I still had the machine and now years later my answer is different, bit embarrassing but I'm getting old and one day will be old so some things either change or the memory slips/slides/fails some times.
I usually don't give answers from the manuals because I don't usually read them.:D :ashamed: :confused2:
   / B3200 kubota hst filter and hydraulic filter #16
I do own the machine in question and I am embarrassed to say that after reading the manual I looked at my machine and did not see the screen in question. After that I checked a printed parts manual and it did not show the screen so I was vindicated. Until I looked at the newest online parts manual and found the screen, then looked at the tractor and to my surprise there it was. Don't know where it was the first time I looked:confused3: Is'nt getting old grand.:drink:
   / B3200 kubota hst filter and hydraulic filter #17
Grew up on farms and ranches. Can do most maintenance on the Kubota. My Brother is a Farm Equipment Mechanic that has worked on most every type of tractor and harvestor. He has been doing that for about forty years. When I ask him a question about a tractor or equipment. His response is "did you read the manual"?
In 1972 I bought a Kubota L210, the manual was written in English but some of it made no sense.
   / B3200 kubota hst filter and hydraulic filter #18
Japanese motorcycle service manuals are the same. If you read the instructions forward, then backwards, have a beer, then read it again, it may start to make sense.
Is there an aftermarket hst filter for the B3200?
John
   / B3200 kubota hst filter and hydraulic filter #19
Gerry,
I am a recent owner of a B3200 and I just completed my 50 hour service. From the threads that I have been reading it appears Kubota has changed their service and maintenance schedule over the past few years. The manual for my 2012- B3200 indicates on the 50 hour service to change the air filter, engine oil, engine oil filter and the HST filter. The manual indicates to change the hydraulic oil and filter at 400 hours. The service was simple and the only oil lost when removing the HST filter was the oil inside the filter.
Good Luck,
Tobyone
   / B3200 kubota hst filter and hydraulic filter #20
Could someone please post a picture of where the screens are on a B3200. Is there one or two or more please?
thank you
Bucket (A55973)
Bucket (A55973)
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
IRET13 ELECTRIC TRICYCLE (A58214)
IRET13 ELECTRIC...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
2003 LEEBOY L150 ASPHALT DISTRIBUTOR TRAILER (A52707)
2003 LEEBOY L150...
