B3200 Clutch Housing drain plug?
   / B3200 Clutch Housing drain plug? #1
Tobyone
Grand Haven, MI
2012 Kubota B3200 HSD w/ FEL, 60 in mid mount mower and 60 in box blade
Mates,
By chance, does any one have a photo showing the location of the clutch housing drain plug, for water removal on a Kubota B3200 Your help would be appreciated.
Thanks,
Tobyone
   / B3200 Clutch Housing drain plug? #2
Tobyone,you can go to Kubota's website,select Parts on the top line and navigate your way to an illustrated parts list for your B3200HSD.Select clutch then clutch housing and I believe #100 is your plug.Surprising in that is not the same as my B3030.FWIW,I've had mine out several times and it's always dry.Hope this helps.Good Luck!
Number two,
Thank you. I looked and looked and could not find the plug based upon the diagram in the owners manual. I appreciate you taking the time to answer my question and for directing me in the right direction.
Tobyone
BOBCAT 260 WELDER/GENERATOR (A52472)
BOBCAT 260...
1984 ASPT 30ft Pole S/A Towable Trailer (A51692)
1984 ASPT 30ft...
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
2022 JOHN DEERE 410E II (A52472)
2022 JOHN DEERE...
STOP!!!! PLEASE READ ALL TERMS BEFORE BIDDING!!! UPDATED TERMS!! (A50775)
STOP!!!! PLEASE...
