B3200 Clutch Housing drain plug?
   / B3200 Clutch Housing drain plug? #1
Tobyone
Grand Haven, MI
2012 Kubota B3200 HSD w/ FEL, 60 in mid mount mower and 60 in box blade
Mates,
By chance, does any one have a photo showing the location of the clutch housing drain plug, for water removal on a Kubota B3200 Your help would be appreciated.
Thanks,
Tobyone
   / B3200 Clutch Housing drain plug? #2
Tobyone,you can go to Kubota's website,select Parts on the top line and navigate your way to an illustrated parts list for your B3200HSD.Select clutch then clutch housing and I believe #100 is your plug.Surprising in that is not the same as my B3030.FWIW,I've had mine out several times and it's always dry.Hope this helps.Good Luck!
Number two,
Thank you. I looked and looked and could not find the plug based upon the diagram in the owners manual. I appreciate you taking the time to answer my question and for directing me in the right direction.
Tobyone
John Deere 1023E (A50120)
John Deere 1023E...
2019 Ford Fusion SEL Sedan (A50324)
2019 Ford Fusion...
2018 KENWORTH T680 SLEEPER TRUCK (A52141)
2018 KENWORTH T680...
RoGator RG1100C (A52748)
RoGator RG1100C...
2018 Bobcat T590 (A50120)
2018 Bobcat T590...
