B3200 axle pivot leak
   / B3200 axle pivot leak #1
mjw357
Platinum Member
The Sticks, Ohio
Kubota B3200
Noticed this today, looks like it has been leaking for a while.
Seems to be leaking at the joint here (arrow)
Is this a DIY fix? I’m fairly handy.
   / B3200 axle pivot leak #2
There's a seal in there. It may be leaking because of normal wear or because it's worn from loose bearings or bushings.
Your shop manual should say how to disassemble and reassemble it
   / B3200 axle pivot leak #3
Yes it is a DIY fix plenty of threads on TBN about fixing it......
Guess I’ll have to get a WSM and search youtube.
*edit*
Found a tube video of the same repair on a BX that looks pretty much identical to a B series in design.
2014 JLG G12-55A 12,000lbs 4x4 Rough Terrain Telehandler (A55787)
2014 JLG G12-55A...
HOLDER C9700H MUNICIPAL TRACTOR (A51406)
HOLDER C9700H...
2013 Chevy Silverado 2500 HD (A55218)
2013 Chevy...
2014 Ford Taurus AWD Sedan (A55853)
2014 Ford Taurus...
New JMR Skidloader Work Basket (A50775)
New JMR Skidloader...
2018 Ford F-150 Crew Cab Pickup Truck (A55788)
2018 Ford F-150...
