B3200 3 point leak down
/ B3200 3 point leak down #1
sbatzold
Should the 3 point on my B3200 leak down when in full raised position with a finish mower on it and shut off or should it be able to hold it in the raised position?
/ B3200 3 point leak down #2
Mine has always leaked down. Never worried about it.
measuring at the back of the mower it leaked down 4" in an hour.
/ B3200 3 point leak down #4
May as well drop the implement to the ground when the tractor is shut off. I always do that.
/ B3200 3 point leak down #5
I bought brand new. Both 3pt and FEL leak down. 3pt with a box blade will lose about an inch a day. Empty FEL about 6 or 7 a day. I just tested it so I would know. When I park it everything is set down every time. Keeps it from possibly rolling away or someone inadvertently hitting a lever heaven forbid when someone or something is under it. Also with pallet forks on most of the time just a couple inches off the ground make for a heck of a shin breaker and trip hazard.
I normally keep it down, but trying to figure out a 3 point problem I have with it not lifting all the way smoothly and wondering if I have a bad valve.
/ B3200 3 point leak down #7
Mine does it too. If I have something I want to stay up and while I'm mowing I'll set my height and just close the 3 pt flow valve under the seat. With that closed it won't leak down at all.
/ B3200 3 point leak down #8
Mine creeks and groans so I am sure its slowly dropping. Not sure about the FEL as I leave it up for two weeks at a time (only way it fits in the shed).
Lincoln Arc Welder (A62613)
Lincoln Arc Welder...
PT 6' Dirt Pan (A64127)
PT 6' Dirt Pan...
New Holland L180 (A64126)
New Holland L180...
2011 PETERBILT 367 (INOPERABLE) (A65643)
2011 PETERBILT 367...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A64556)
2018 Ford F-150...
Wolverine TL-12-72W 72" Skid Steer Tiller (A62679)
Wolverine...
