B3030HSDCC Keys
   / B3030HSDCC Keys #1
Earl Ohl
B3030HSDCC, Oliver 77, JD LX288
Hi, I'm a long time reader but never posted before. I have a B3030HSDCC a little over a year now and just today learned something. My nephew was using it today and when he parked it in the shed he removed the key from the ignition by mistake and when he replaced it he put the key for the doors in the ignition. Then when I came there to move it the key would turn the switch but the tractor would not crank. After I spent about 5 minutes looking around for a problem I saw the wrong key was in the switch. After I put the correct key in the ignition it started right up. I thought I'd post this as a FYI just in case this happens to someone else.
   / B3030HSDCC Keys #2
I took the key out once also and was surprised as to which of the two keys worked the ignition when I tried to start it the next time.
   / B3030HSDCC Keys #3
Same thing happened to me. When I was first checking out the Kubota lineup,the salesman gave me a B key and a L key and sent me out into the lot. That's when I found out the L key opens the B3030HSDC doors,but does that thing with the ignition switch. Makes me wonder if the door handle assemblies on the B are from the L series.
2008 JACK COUNTY  130BBL VACUUM TRAILER (A50854)
2008 JACK COUNTY...
2018 VOLVO VNL SLEEPER (A51222)
2018 VOLVO VNL...
2018 ISUZU FTR 24FT BOX TRUCK (A51222)
2018 ISUZU FTR...
71061 (A49346)
71061 (A49346)
2018 LAYMOR SM450-ST SWEEPER (A51242)
2018 LAYMOR...
Landoll (A50657)
Landoll (A50657)
