B3030dashboard cowling seems loose
   / B3030dashboard cowling seems loose #1
jstreet
Honeoye, in western NY
Kubota B3030
The plastic cowling assembly on my B3030 (surrounding the instrument panel and extending down to the floor) seems quite loose. I can wiggle it easily by grasping with both hands on the sides. I see no readily apparent way to tighten it up. Is this looseness normal? If not, how can I tighten it? Thanks.
   / B3030dashboard cowling seems loose #2
Buy a Kioti
   / B3030dashboard cowling seems loose #3
tractorhill said:
Buy a Kioti
:D :D :D
Or, learn how to spell.;)
I've never managed to post inadvertently in the Kubota section but I have managed to start reading that section when I thought I'd clicked on Kioti.:confused:
   / B3030dashboard cowling seems loose #4
A Kubota is a dang fine machine. A B3030 is also a dang fine Kubota. I just don't think you, jstreet, will find the answers here.
Hey, my clear instrument panel cover leaks dirt past its seal. I have a waterfall of dust on top of the gauges but no water yet.
   / B3030dashboard cowling seems loose #5
Yep, a 3030 was on my short list.
2010 KMC 3376 Peanut Combine (A56438)
2010 KMC 3376...
1995 NEWTON CROUCH PULL SPREADER (A58375)
1995 NEWTON CROUCH...
2002 Ford F-150 Pickup Truck (A56858)
2002 Ford F-150...
New/Unused Quick Attach Wood Chipper (A57454)
New/Unused Quick...
ROBIN AIR 34788NI A/C RECOVERY MACHINE (A58214)
ROBIN AIR 34788NI...
2011 DRAGON 130BBL VAC TRAILER (A58214)
2011 DRAGON 130BBL...
