B3030 with Woods BX80 or B21
   / B3030 with Woods BX80 or B21 #1
toolcollector
As stated in another thread, I am ready to order a B3030 and a Woods BX80 primarily for projects and landscaping 2.5 acres. I know a few on here have this same combo and seem to love it. I will not be mowing with this unit and the money seems very close to a B21, especially a lightly used one. Should I be trying to compare the two and for landscaping and loader work, should I be considering a B21 instead. Anyone knows the loader specs of the B21 vs. the 403 that comes on the B3030.
Thanks for the info...
   / B3030 with Woods BX80 or B21 #2
The major difference between B21 and B3030 loaders is: B21 is self-leveling. It's a bit more powerful too (926lbs vs 880lbs). The major disadvantage with a B21 is the engine: 21HP. It gives you 13.5HP at the PTO :eek: . Compared to a B3030 with 30HP engine and 23HP PTO the B21 seems anemic. If you plan to use a lot of rear implements connected or not to the PTO you definitely should go for a B3030... IMHO ;) .
   / B3030 with Woods BX80 or B21 #3
Look carefully at the two side by side the B21 is far more heavy duty than the B3030. The B21 also has bushing in the loader which can be changed out as they wear. The B21 loader is non-removable while the B3030 loader is removable.
   / B3030 with Woods BX80 or B21 #4
I wonder when the B21 will be replaced with a new updated model. Been around for a long time now.
   / B3030 with Woods BX80 or B21 #5
Word around the campfire is that kubota is in a working on a new b21 now.
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A51039)
Kubota 24in Quick...
C13 MOTOR (A50854)
C13 MOTOR (A50854)
2016 FORD F-150XL SINGLE CAB TRUCK (A51406)
2016 FORD F-150XL...
2020 CATERPILLAR Tl1255D TELESCOPIC FORKLIFT (A51242)
2020 CATERPILLAR...
2020 Kubota Z723KH 48in. Zero Turn Commercial Mower (A50324)
2020 Kubota Z723KH...
2018 PETERBILT 579 DAY CAB (A51222)
2018 PETERBILT 579...
