B3030 with cab:
   / B3030 with cab: #1
FRIZ
Bronze Member
NW Indiana
John Deere 4720 Cab
How high (tall) is the B3030 with cab and turf tires?
Thank you.
Regards,
FRIZ
   / B3030 with cab: #2
I'm going to call mine between 7', and 7'-1" to the top of the ridges in the center of the roof panel. This in with my rear directionals turned down some, as they are taller than the roof in the factory position. I also had to angle my radio antenna down (which didn't seem to affect reception). This was to fit under my 7' overhead door opening, which I still had to rework a bit (and I still need to finish) to get the tractor inside. If height is a concern, a 3030HSDC with R4s should just squeek in with no modification (but watch the directionals).
   / B3030 with cab: #3
I haven't measured but I did try my B3030 HSDCC with R-4's and it will not fit in at our 7 ft. garage door at the house. It's maybe 1/2 to 1 inch too high. The building where it's kept in has a 10 ft. high door so it's not a problem there.
2008 STEPHENS 220BBL CRUDE OIL TRAILER (A50854)
2008 STEPHENS...
YARD MACHINES MOWER (A50854)
YARD MACHINES...
1994 Mack CH613 T/A Wet Kit Day Cab Truck Tractor (A49461)
1994 Mack CH613...
1043 (A50459)
1043 (A50459)
CAT 420F2 IT (A50854)
John Deere Ztrak M665 60in Zero Turn Mower (A48082)
John Deere Ztrak...
