B3030 vs JD 2520 - Which one?
   / B3030 vs JD 2520 - Which one? #1
Lindy
Western NY
Kubota B3030, John Deere 325, (Former) '53 Ford Jubilee
This board is great -- I've learned so much about CUTs during my search over the last few weeks.
I think I've narrowed it down to two different tractors: Kubota B3030 or the JD 2520.
Intended Use:
I have about 6 acres. Some gentle slopes, but no serious hills. The whole things needs to be finish mowed. We have a few trees, but not a lot. The ground is pretty bumpy in some areas -- especially the reclaimed pasture/farmland. There are some areas I'd like to level off by shaving and reshaping. Other areas need to be built up. The topsoil has a lot of clay and stays pretty soggy in the spring. Lots of blowing, drifting snow in the winter. We get a lot of wind, and our 500' blacktopped driveway is in a really bad spot (too low and too close to the pasture fence). We have a garden to maintain, and other miscellaneous mulching/topsoil work to do.
For the mowing, so far I've gotten by with a JD 325 lawn tractor, 54" deck. But the pasture pounds the crap out of that poor little tractor. It's nice, but it wasn't made for 6 acres. I currently (try to) use an ATV with a 50" snow plow for snow detail in the winter, but it takes a REALLY long time. If I don't plow ~5 driveway widths the entire length of the driveway, the next snowstorm or windstorm will drift us in really good. Often I wind up having to "bulldoze" the snow because the ATV is not heavy/powerful enough to push the snow to the side without spinning me in a circle. The snow moves ME instead of me moving the SNOW.
The Comparison & Price Check:
I think I've narrowed it down to 2 tractors.
1. Kubota B3030, LA403 FEL, 60" MMM, R4's ==> $18.5k
2. John Deere 2520, 200CX FEL, 62D MMM "Onramp", R4's ==> $18.4k
Are these prices reasonable? Which is the better deal? I'm leaning towards the Kubota, but I've always liked JD. I test drove them both. The 3pt on the 2520 kept hitting the rear tires (R4's). Didn't like that. The Kubota seemed really smooth, but perhaps the hydraulics weren't quite as fast.
What do you think? Are these tractors good ones for the jobs I listed above?
Thanks!
   / B3030 vs JD 2520 - Which one? #2
I'm looking myself, and have looked at both tractors too. I like them both, and think they both would do a good job for the chores you have in mind. Actually, the Kubota B2630 is more of an even match for the JD 2520, and is less expensive. I don't like the 3pt hitch rubbing on the JD, and have been following posts about it, but I do like the drive over deck. I think the 3pt setup is much nicer on the Kubota, and it has more power, and a very useful 3 range hydro. I guess I would take the JD 2320 over the smaller B series, but I would take the Kubota B2630/B3030 over the JD 2520. The other big advantage for your snow situation is that the Kubota has a 63" snowblower / 72" front blade available while the JD front mounted implements (blade /snowblower) are considerably narrower than the 2520 wheel width. Something to think about
These same things crossed my mind, and I agree with you on all of them.
Hmmm. Good point. Thanks for the heads-up. Didn't know about that. The original plan was to get a 3pt snowblower as part of the pkg deal, but I've decided to stick that $$ into the tractor instead and add the blower later. At least I'll be able to dig myself out now with the FEL if worst comes to worst.
   / B3030 vs JD 2520 - Which one? #4
I vote for the Kubota. I have a B3030 and have compared it extensively with the JD2520. The 2520 will probably do anything the Kubota will do but the Kubota will do it better. 3 speed trans. 3PTH arms that don't rub the wheels. More ground clearance. Taller rear tires. Metal hood and fenders. A flatter deck making it easier to get on and off. An excellent seat on the new models, I have the new seat on mine. Bottom line is that the Kubota is more machine for the money IMHO. You will not be disappointed. Good luck.
   / B3030 vs JD 2520 - Which one? #5
I know the B3030 will be a good match for your needs as i have owned/operated one for 2.5 years. I cant chime in on the deere as i know nothing about them. I hope you have some cash set aside for the chiropractor, because your going to need it if you plan to clear that 500 foot driveway with a rear snowblower! :D
Ha! True. But it's gotta be better than the current 3 hours of slamming and pounding I'm taking on the 4 wheeler right now. Man, once those snowbanks settle in, it's almost impossible to move them with that little thing.
Couple things regarding a front snowblower:
1. Are they maneuverable enough to clean out the tight spots?
2. Don't you miss the ability to scoop & pile?
3. Those things are awfully expensive :eek:
   / B3030 vs JD 2520 - Which one? #7
Lindy,
Last summer I was ready to buy a B3030. Then I test drove three of them. All had a very annoying vibration problem. Annoying to me, that is. A lot of people don't seem to mind or even notice it. On one of the tractors, the FEL control lever and the pins for the folding rops rattled so much at idle that I thought they might grind themselves into dust. On another, my feet went numb on a 5 minute test drive around the lot. I figured I would learn to live with it.
Being a Kubota guy, I didn't even plan to look at the other brands. On a whim, I stopped by a JD dealer. Long story short, I ended up on a JD 3320. Similar HP to a B3030, but way more tractor in most other respects. And a silky smooth 3cyl motor. Don't let the physical size of the 3000 series scare you. They are very agile and easy to maneuver. And the larger tires, higher weight, and real suspension seat (not the pseudo version like the B3030) make it a ride like a Cadillac on rough terrain.
My biggest misgiving on this tractor was all the fly by wire electronic wizardry that seemed like completely unnecessary complexity. And perhaps it is. But it is very pleasant to use. The auto style cruise with resume feature is my favorite.
Good luck and happy shopping.
KB
   / B3030 vs JD 2520 - Which one? #8
I'd go with the 3030 and try to get a cab with it. They sold last year in Kansas for $18,950, cab and tractor only, with heat and ac. A co worker bought one and he loves it. He got a loader as well but don't know what his final price was.
   / B3030 vs JD 2520 - Which one? #9
The B3030 will run a 72" MMM. With 6 acres of grass to cut, I'd be looking at the big deck.
That's a really nice rig you've got there, KB, don't tempt me! Thanks for the pic. But that tractor would be another $4.5k or so for a similar setup at my local dealers, and I just can't spend that much. I've already gone over my original budget by quite a lot :eek: They had a factory cab model at one of the dealers I visited, and it was really, really nice. It's just too much $$$.
Thanks for the heads-up on the vibration on the B3030. I didn't notice it at all when I took a test drive, but I'll check for it again. If anything, from what I recall it seemed smoother to me than the other one I test drove (B7510).
GENERATOR HOUSE POWERED BY TWIN (60 SERIES)  DETROIT 14.0L ENGINES (A50854)
GENERATOR HOUSE...
2018 FORD EXPEDITION (A51406)
2018 FORD...
2015 KENWORTH T370 QUINT AXLE DUMP TRUCK (A51222)
2015 KENWORTH T370...
SOLDERING IRONS, GLOVES, AND STANDS (A50854)
SOLDERING IRONS...
2017 DITCH WITCH RT30 RIDE-ON TRENCHER (A51242)
2017 DITCH WITCH...
CATERPILLAR D8T HI-TRACK CRAWLER DOZER (A50458)
CATERPILLAR D8T...
