amigauser
Veteran Member
I know I wondered if the Kubota factory quick hitch (which allows use of the factory front blade, front snowblower and front broom) was compatible with the Kubota mid mount mower front hanger support. I knew the mower itself would have to be removed but I was not sure until today if I had to remove the front mower support hanger before mounting the quick hitch.
Well I found out this morning that the quick hitch mounts fine with the front mower hanger mount still in place
. At least that is the case with the front blade which is what I have. I am not sure if you have the mid pto coupler installed (which would power a front snowblower and/or front broom) as I do not have that option.
I had read/heard that the older Kubota "B" series required the front mower mounting hardware to by physically removed before the quick hitch could be mounted but they apparently fixed that problem on the newer "B" series.
FYI,
Norm
FYI,
Norm
