B3030 owner questions???
   / B3030 owner questions??? #1
czr
Stopped by the dealer to inspect and test drive my new B3030 before he transports it to me . 1. I noticed when in hi gear (rpms around 1500) and I step on the petal lightly to try to slightly inch forward it will lurch forward. The service manager says this is part of the design of the transmission?This does not happen in the lower 2 speeds.2.On a slight inline the tractor will roll backwards or freewheel with my foot off the accelerator petal. Can this be adjusted so that it will not roll on a incline when my foot is not on the petal? My B 7300 tractor stopped every time and would not even roll on a incline. 3. Are the rear outlets just a plug and cover plate located near the rear transmission? 4. Has anyone heard of when the fix is coming for the vibration issue? I spoke to the technician at Kubotas Northern Division in August and he said it should be coming soon. I was really pleased with the performance\features of the B7300 tractor and hope this one performs as well.
   / B3030 owner questions??? #2
I have not noticed mine lurching foward in high gear. I dont think I have a vibration issue however my FEL is one that is off. I like the tractor it meets my expectations in performance.
   / B3030 owner questions??? #3
Hi CZR, If you have the RPM up and hit the pedal it's going to lurch to a degree,Like in your car,rev it up and drop it in gear it's going to go,will be more noticeable in higher gearI do not have a FEL problem,nor do I have any bad vibration others have talked about. As far as freewheeling on hill I have not noticed,will check it out and let you know.Rear hyd. outlet is in the rear/right side,sort of a diamond shape plate.I really like my B3030,just the right size and power. /forums/images/graemlins/smile.gif Best Regards wbfllamas
   / B3030 owner questions??? #4
czr,
</font><font color="blue" class="small">( <font color="red"> I noticed when in hi gear (rpms around 1500) and I step on the petal lightly to try to slightly inch forward it will lurch forward. The service manager says this is part of the design of the transmission?This does not happen in the lower 2 speeds. </font> )</font>
<font color="blue"> Mine does the same thing, but it never bothered me. </font>
</font><font color="blue" class="small">( <font color="red"> On a slight inline the tractor will roll backwards or freewheel with my foot off the accelerator petal. Can this be adjusted so that it will not roll on a incline when my foot is not on the petal? </font> )</font>
<font color="blue"> Mine does the same thing too. My former BX23 did it too. For me it's normal. If I have to step down I use the breaks, if not I use the hydro-pedal to immobilize the tractor. I don't like it too much when the hydro transmission stops the vehicule too hard (like a RTV for instance).</font>
</font><font color="blue" class="small">( <font color="red"> Are the rear outlets just a plug and cover plate located near the rear transmission? </font>)</font>
<font color="blue"> I don't understand your question. If you have a backhoe installed then a rear outlet came with it (free flow). You can add too rear auxiliary outlets with valves (see the picture) if you want but it'll cost you more. </font>
</font><font color="blue" class="small">( <font color="red"> Has anyone heard of when the fix is coming for the vibration issue? </font> )</font>
<font color="blue"> I have vibration and I'm looking forward to get a fix asap but so far we don't know when it'll be ready. </font>
   / B3030 owner questions??? #5
i like mine a lot too. very capable for size. some people say it's too light but i can add weight when i need it and take it off when i dont. i had a jd2210 (great little machine also) prior to this. 3030 will go places 2210 could not due to more ground clearance and folding rops. the 3ph also stays where you put it rather than up or down and doesn't bleed down. mine does vibrate more than i like and fel is off like others but neither is a major issue to ME and wouldn't change my mind about doing it again. 15 hours of motoring bliss so far
2020 PETERBILT 337 BOX TRUCK (A51222)
2020 PETERBILT 337...
2013 Ford F-150 4x4 Ext. Cab Pickup Truck (A48081)
2013 Ford F-150...
2015 FONTAINE VELOCITY 102" X 48' STEP DECK TRL (A50459)
2015 FONTAINE...
1981 LINK BELT HSP 8028 (A50854)
1981 LINK BELT HSP...
2008 FORD F-750XL SUPER DUTY ASPHALT DISTRIBUTOR T (A51243)
2008 FORD F-750XL...
3014 (A50657)
3014 (A50657)
