B3030 - need power to hook up tow behind sprayer
   / B3030 - need power to hook up tow behind sprayer #1
mikehsanders
Madison, MS
kubota bx2200
Does anyone know of an unused connector or other source of power useful for hooking up a sprayer. I saw a thread on power under the seat of a BX series and hope something similar is available on the B model
   / B3030 - need power to hook up tow behind sprayer #3
</font><font color="blue" class="small">( Does anyone know of an unused connector or other source of power useful for hooking up a sprayer. I saw a thread on power under the seat of a BX series and hope something similar is available on the B model )</font>
If...IF...you DONT have a rear worklight on the tractor..?? you have an unused 15 amp circuit and the end connector is located up under the right rear light on the rear fender. If it IS already in use...just remove the connector and "splice in" a "Y" connector there...but you wont be able to run the light and use power for a sprayer at the same time
   / B3030 - need power to hook up tow behind sprayer #4
   / B3030 - need power to hook up tow behind sprayer #5
Yep, Sully2 is right. Under the right rear light. If you didn't use it for a working light (pdf file)
  • 899579-12Vplug.pdf
   / B3030 - need power to hook up tow behind sprayer #6
Sully, Stef
Thank you for the valuable info. I'm going to get right on it.
Sully, Stef
2012 PETERBILT 388 SLEEPER TRUCK (A51222)
2012 PETERBILT 388...
100 GAL FUEL TANK (A50854)
100 GAL FUEL TANK...
AC CHARGING MACHINE (A50854)
AC CHARGING...
2011 L3 GENERATOR SET (A51222)
2011 L3 GENERATOR...
2024 Chevrolet Silverado Pickup Truck Bed (A49461)
2024 Chevrolet...
WEATHERFORD MP-10 TRIPLEX MUD PUMP POWERED BY A CATERPILLAR 3412 ENGINE (A50854)
WEATHERFORD MP-10...
