B3030 Loader (LA403)
   / B3030 Loader (LA403) #1
Steve_Miller
Veteran Member
Nova Scotia, Canada
2006 Kioti CK30HST
Loader has no down pressure, lots of lift pressure. Float position works. Swapped hoses with curl function and loader lifts in both directions, only drops when lever is put into fast dump position. Have heard someone say that you cant swap to troubleshoot this way as there are different pressure settings or other things going on in the valve body. Curl function seems to works properly though when swapped. I was assuming I had a cylinder bypassing but cant explain why it bypasses going down but not up. Any hydraulic gurus that have run across this issue? Blown 'o' ring in spool body down position?
Steve
2015 Linde Diesel Forklift (A49346)
2015 Linde Diesel...
2016 Ford F-450 Knapheide Service Truck with Liftgate (A48081)
2016 Ford F-450...
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A48081)
2015 Ford F-550...
2013 FORD F550 SHUTTLE BUS (A50505)
2013 FORD F550...
UNUSED U Bolt Wire Rope Clamp Set (A50860)
UNUSED U Bolt Wire...
Terex Loader Arm (A49346)
Terex Loader Arm...
