B3030 Hydrolic Fluid Level
   / B3030 Hydrolic Fluid Level #1
nwheeler
What should the fluid level be with the backhoe? Dealer told me to retrack all cylinders and check fluid. It shows full, but under normal driving conditions, it doesn't show up on dip stick at all. Doesn't seem accurate.
   / B3030 Hydrolic Fluid Level #2
To check transmition fluid level park on level , turn off engine, pull out dipstick and level should be between the two marks. Same procedure with or without backhoe. Although if you di just change fluild or just put hoe or loader back on, it would be good to operate controls full range to make sure no air in lines. I would not check level while engine running like on a car as manufacturer does not recomend checking with the engine on in manual.
2022 CASE TV370B SKID STEER (A51242)
2022 CASE TV370B...
John Deere 6410 Loader Tractor (A50514)
John Deere 6410...
Komatsu PC490LC-11 Hydraulic Excavator (A49346)
Komatsu PC490LC-11...
Unused 2025 CFG MX20R Mini Excavator (A49461)
Unused 2025 CFG...
2011 INTERNATIONAL PROSTAR +122 6X4 DAYCAB ROAD TR (A51243)
2011 INTERNATIONAL...
2019 Doosan DX225LC-5 Excavator (RIDE AND DRIVE) (VERY NICE) (A50774)
2019 Doosan...
