B3030 HSDC (1 year-125 HOUR) REVIEW
   / B3030 HSDC (1 year-125 HOUR) REVIEW #1
lawn_king
Veteran Member
Hanover massachusetts
kubota L 3540 hsdc,B 2320 hsdc & lots of other stuff!
On a scale of 1-10, i would rate the 3030 a solid 9. Balance,steering,fuel consumption are good, brakes are strong, hydro shifts easy after break in & 50 hour service, 14" of ground clearence makes it easy to get under the machine and the access to service is a walk in the park. The differential lock pops in and out easy, cruse control is as good as my tahoe, motor is quiet, hydraulics are strong with outlets front & rear, position control, let me say this, once you have it, you cant go without it. Independent hydraulic pto engages smooth and quiet, 3 ph has telescoping ll & sway arms as well as ratchet lift arm level, making hitch up fast and painless. 403 fel is well matched to the 3030, the remote loader control is far superior to the standard kubota joystick! The cab is high quality, heat & AC crank, stereo is very nice, speakers are ok not great. My dislikes on this machine are few, i really wish the rear tread was adjustable, the seat takes a lot of time to find a comfortable position and even then its boader line comfort. The top of the line tractor in any series should include a full needle gage package. I feel the extras on the 3030 are worth the extra cost, if you use your tractor to mow once a week, the 7800 may be up your alley, also a fine machine.
   / B3030 HSDC (1 year-125 HOUR) REVIEW #2
A coworker of mine bought a B3030 cab with FEL, MMM, and R4's. I spoke with him about it on Friday, he really likes his. He said that he goes out in the heat to mow and the AC doesn't seem to rob him of any power.
The only loss to the ac i see is some fuel, if i am running the ac and the pto brush hogging you burn up some fuel, but thats to be expected.
   / B3030 HSDC (1 year-125 HOUR) REVIEW #4
I'm looking at purchasing the same tractor. I hear it is noisy inside the tractor, could you please confirm this. Not farmiliar with remote joy stick.
   / B3030 HSDC (1 year-125 HOUR) REVIEW #5
It is not loud in the cab at all. Just nice levels of backround noise even at full power.
Jeff
2013 Chevrolet Silverado 2500HD 4x4 Crew Cab Knapheide Service Truck (A48081)
2013 Chevrolet...
2007 Terex RS350 Soil Stabilizer/ Reclaimer (A49346)
2007 Terex RS350...
2007 Freightliner M2 106 12Yd T/A Dump Truck (A48081)
2007 Freightliner...
Segway i2 Personal Transporter (A48082)
Segway i2 Personal...
Vacuworx Vacuum Lifter Pad (A50860)
Vacuworx Vacuum...
2014 Nissan Quest SL Van (A48082)
2014 Nissan Quest...
