Oil & Fuel B3030 fuel consumption
   / B3030 fuel consumption #1
johnnyreb
I am using about 1 gallon per hour of operation with my B3030 pulling a 5 ft cutter (about 550 lb). Does this seem about right?
   / B3030 fuel consumption #2
I would not complain
I was wondering what my B2910 was consuming. It stands to reason that
the higher the rpm's the more fuel you consume. The only time I go near
2600 rpms is when I have the tiller on. The rest of the time about 2200.
I used to own a B7200 never figured out what the fuel consumption was
but a 5 gallon can of diesel would last forever.
   / B3030 fuel consumption #3
That really sounds like allot of fuel consumption.
I normally get 2+ hours per gallon on either our L-3130 or L-39, but they are both three cylinders..
   / B3030 fuel consumption #4
Yeah, that's what I was thinking ..... I think our B2910 uses around 0.6 gallons per hour ... and it is a 4 cylinder.
   / B3030 fuel consumption #5
Best I can figure I use also about one gallon per hour on the M7040 mowing with a 15 ft woods mower. Some areas go uphill where i have to go to full throttle to maintain PTO speed. Generally mowe in fourth gear at 2200 rpm at a speed of 4.5 miles per hour
   / B3030 fuel consumption #6
I got .66 gallons per hour last time I checked, but that was a mixture of mowing and FEL work, the best RPM for me when mowing is 2100-2200 rpm a little below the 540 Pto mark (2400), I can see getting 1 gallon per hour with heavy tall grass and brush mowing.
   / B3030 fuel consumption #7
My 3030 burns about .5 gals per hour brush cutting @ pto speed, Pulling a 1000 lb. core aerator she burns 1 gal per hour. I have not done the sea trials on our 2782 front snowblower yet, Im sure she will burn 1 -2 gals per hour with the throttle up and the mid pto engaged.
   / B3030 fuel consumption #8
I have a 30 hp Kioti with a 60" rotary cutter and since the paint colors are nearly the same I think it at least compares.
I also burn just about a gallon per hour at PTO speed while mowing. Silly little 8 gallon fuel tank needs to be refilled during the work day.
   / B3030 fuel consumption #9
Mine seems to just sip fuel but I never mow with it and do everything at just above idle
   / B3030 fuel consumption #10
I have a B7800 with about 30 hours of use and I am using about 5 gallons every 8 hours. I use it mainly for mowing so it is set to PTO RPM most of the time.
72in Rock Bucket Skid Steer Attachment (A50322)
72in Rock Bucket...
2014 STONE RIDGE 38FL 5TH WHEEL CAMPER (A50854)
2014 STONE RIDGE...
Sakai TS160 TTS5 Pneumatic Asphalt Roller (A49461)
Sakai TS160 TTS5...
2015 WESTERN STAR 4900 SF (A50854)
2015 WESTERN STAR...
196046 (A50459)
196046 (A50459)
SHOP MADE  MANIFOLD TRAILER (A50854)
SHOP MADE...
