b3030 fel and bh leaking down
   / b3030 fel and bh leaking down #1
botamoose
what would cause a fel and a bh to be leaking down that bad that when you stand on them you can watch it?? the bucket,arms and bh all does it. thanks for reply
   / b3030 fel and bh leaking down #2
I would look at all the hose connections and see if there is a leak to be found.
A slow leak down over a few days is normal but a quick leak down (a few hours) is not. Check all hydraulic connections. Remember to be very careful when working around hydraulic fluid.
Bill
THERE IS NO LEAKS CHECKED FLUID AND EVERYTHING IS OK.YOU CAN STAND IN THE BUCKET AND WATCH IT TIP DOWN.
   / b3030 fel and bh leaking down #4
You have two problems or more with the system as they both operate off different controls. There are always two possibilities with any leak down, the valve or a cylinder.
UPDATE TOOK TRACTOR BACK TO DEALER AND THEY FOUND MELTAL SHAVINGS IN THE CYCINDERS WHICH DESTROYED THE SEALS. CORRECTED PROBLEM AND OK NOW
2006 John Deere 310SE 4x4 Loader Backhoe (A49461)
2006 John Deere...
1240 (A50490)
1240 (A50490)
2018 Dodge Ram 5500 Bucket Truck - 4x4, Versalift VST40, 45FT Reach, Dakota Line Body (A51039)
2018 Dodge Ram...
2022 Wacker Neuson SM100 Mini Skid Steer (A51039)
2022 Wacker Neuson...
2007 FORD F-450 (A50854)
2007 FORD F-450...
2018 BIG TEX 35+5 T/A GOOSENECK (A50854)
2018 BIG TEX 35+5...
