Price Check B3030 CAB PRICE
   / B3030 CAB PRICE #1
TeddyD
SW Mass
Hello everyone, I am looking to make my first tractor purchase. I am considering a kubota 3030hdsc and I have received a price from my local dealer. Just wondering if it's a fair price. /forums/images/graemlins/confused.gif
Options included are loader, woods backhoe, winter upgrade package, 60" rotary broom. Price is $36,000. Is this a fair price? Also considering a 60"mmm. Also wondering if anyone has had any luck with a bagging kit and does this tractor give a nice finish cut for a lawn. Thanks for the help.
   / B3030 CAB PRICE #2
I can't speak about the price although unless you are in Canada it seems high. I do have a B3030 without the cab, with the 60" MMM. It does an amazing job of cutting. The one thing I don't like about the 60" MMM is the the two rear wheels that are close together in the back. They leave tracks that just don't look right on the cut lawn. I have solved that problem though by using chains to hold up the mower in the rear and raising the rear wheels all the way up so they do not touch the ground. The next step is to remove the wheels altogether as they are not needed and just get in the way when removing and installing the mower. I don't have any pictures yet of the chain system but, I am quite pleased with it and think it is a very simple and effective way to eliminate the tracks of the rear mower wheels. I also like the fact that the mower is now partially held up by the tractor instead of all of the weight being on the small wheels. I think when the ground is soft in the spring it will do a better job as the tractor will not allow the mower to cut into the soft ground. If the area you are going to mow is open enough you might want to consider the 72" MMM. It has a four corner wheel setup that I think will leave a better looking cut lawn. Otherwise, I love the 60" mower. It is amazing how fast I can travel and still do a fine job of mowing. Kubota definitely has their mowers figured out.
   / B3030 CAB PRICE #3
I posted for you in the JD thread but I checked the local B3030 cab price for you tonight and the tag said $25030 for cab B303 and Loader (not sure which one) here in Bloomington, IL.
Hope that helps you.
   / B3030 CAB PRICE #4
That sounds about right as i paid $ 28900. for B3030 factory cab, am/fm/wb/cd, turf tires ( rears filled) 403 fel and 2782 front snowblower. Signed on the line 2 weeks ago!
   / B3030 CAB PRICE #5
The local dealer near me had a sales sticker for just under $17000 for a cab model b3030. No loader or anything else. Looked like quite the machine. I did not check to see what features were on the cab at that price.
   / B3030 CAB PRICE #6
AESANDERS,
WHich dealer was that? Hickory, Baltimore Turf, or the Old Richardsons' ?
Thanks, Tim
   / B3030 CAB PRICE #7
It is the Frederick Kubota dealer. They say they are the largest dealer in the state.
Frederick Kubota & Equipment Co 9640 Liberty RD Frederick MD 21701 301-898-1200
   / B3030 CAB PRICE #8
I'd also check out Messick's just across the border in PA. Good dealer and frequents this forum.
   / B3030 CAB PRICE #9
If your close to Frederick I'll put in a good word for them, they are good Guys. Of course if your north at all we would be more than willing to help you out as well.
   / B3030 CAB PRICE #10
I'm In Kingsville which is a little NorthEast of Baltimore. I'm closest to Hickory Intl or Balt. Turf ( Same Company). I used to deal a lot with the old Richardson's, now called Backyard Power. But since Richardson's was bought out by this new guy, this place has turned to the "Dark Side". Twice as expensive as any other dealer, extremely poor to non-existant customer service, and owner with a bad attitude.
Frederick is just as close as Woodbine to me. There used to be a gentleman by the name of "Mike" that I talked to once at Frederick Kubota. I can't find a web site for them.
I just recently compared a general service package from Hickory and Backyard power and Backyard power was $300 MORE than Hickory for the exact same service.
Exactly where is Messick Farm Eqpt?
Thanks for the info.
Tim
10 Ft Fork extensions (A50322)
10 Ft Fork...
71050 (A49346)
71050 (A49346)
2019 Tico Yard Spotter Truck - Cummins Diesel, Allison Auto, Hydraulic Air Fifth Wheel, Cab w AC (A51039)
2019 Tico Yard...
2014 Brent 1596T Dual Auger Grain Cart (A50657)
2014 Brent 1596T...
MAHINDRA 2816 TRACTOR (A51243)
MAHINDRA 2816...
2013 VERMEER RTX1250 RIDE ON TRACTOR (A51242)
2013 VERMEER...
