B3030 Cab Height
   / B3030 Cab Height #1
sugarloafguy
New Gloucester, Me
New Holland TC29DA/14LA Loader and Tc24DA/12LA Loader
Hi,
Anyone know if a 3030 cab will fit inside a standard height garage door?
Brian
   / B3030 Cab Height #2
A 3030 HSDC with R4 tires will just make it in a standard 7' door......but its really close. With the turf tires, it will not fit without modifying the opening.
   / B3030 Cab Height #3
I Just fit under the frame with my unit. It has R4 tires. The rubber sweep on the bottom of the garage door sweeps the top of the cab in the middle of the door (double wide garage door) where the garage door sags ever so slightly more than the sides, which are held with no sag by the bearings. I now make sure I come on the ends so I avoid the rubbing, although it is very slight. You will want to watch to see that the rear flasher/turn signals are turned down. Mine originally were twisted around so they were a few inches higher than the cab
2020 MACK PINNACLE (INOPERABLE) (A50854)
2020 MACK PINNACLE...
CUSTOM ALUMINUM 16FT CAR TRAILER (A51222)
CUSTOM ALUMINUM...
2007 INTERNATIONAL SF625 BUCKET TRUCK (A50854)
2007 INTERNATIONAL...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50774)
IF YOU BID ON AN...
Hyster H155XL Forklift (A48837)
Hyster H155XL...
2012 FREIGHTLINER M2 TANDEM AXLE DUMP TRUCK WITH A SNOW PLOW (A51222)
2012 FREIGHTLINER...
