garc
- Joined
- Jul 27, 2008
- Messages
- 114
- Location
- Vancouver Island, BC, Canada.
- Tractor
- 05 Kubota B3030 ROPS
Though I realize they are not hydraulic lines. (they are control cables to the remote joystick). I agree with lawn king, they do look very exposed.lawn_king said:Those hydraulic lines hanging out in the open are a disaster in waiting. Drill a hole through the floor and run them tucked up tight to the underside of the machine.
Look again. What you see are not hydraulic lines but are the push-pull cab remote loader valve cables installed by the dealer per Kubota set-up instructions for the ROPS model when the tractor was purchased. I changed the routing 2 years ago although it worked for a year trouble free. Take a moment and look at the pictures on the link.lawn_king said:Those hydraulic lines hanging out in the open are a disaster in waiting. Drill a hole through the floor and run them tucked up tight to the underside of the machine.
lawn_king, no pain so I guess you didn't look at the pics. Mine is done the same way but even less exposed that the HSDC. Also my relocated remote loader control is more comfortable to use than the original mount (same as the HSDC) and far more comfortable than the standard valve mounted control. Wouldn't have done it otherwise.lawn_king said:I had a B3030 hsdc, the control cables went through the floor and under the machine to the valve, far less exposed than yours. Im just trying to save you some pain.
3 yr. old photo of Kubota dealer "factory" new install as previously stated. This is all explained in previous posts on this thread. Click on this for a 2 yr. old photo (previously posted).lawn_king said:I did look at the photos,1st photo, those cables are hanging down beside the floor on the right side, very exposed.
