B300 hydraulics
/ B300 hydraulics #1
capt_met
northeast tennessee
Bobcat B300
hello,
i have a B300 bobcat. it is a great machine and amazes me every time i run it. it does have one downfall. i would like to run attaachments on the front that require low flow hydraulics. the way the B300 is set up the hydraulic flow goes up or down related to how much the throttle is pushed. so for me to have the flow up where i need it i would also be moving too fast forward or reverse for the machine. i have read the posts by mchalkley on his earthforce and plan on trying to follow his lead and install a pilot control valve to control the flow to the drive and control my engine and hydraulic pump output with the throttle for the backhoe. it would sure be nice to get in touch with mchalkley and get a tip or two from him on setting this up. otherwise i will just follow my nose and see what i come up with. i haven't seen mchalkley post in a while. if anyone knows how to get in touch with him i would appreciate any help. otherwise open to suggestions from anyone about how to best accomplish this.
thanks in advance,
metin
/ B300 hydraulics #2
I just searched his username for you, he has not posted since 4/19/05.
Have you tried to PM him? The PM may trigger an email to him...
That is the best I can help /forums/images/graemlins/confused.gif
/ B300 hydraulics
kennyd,
i tried to message him and didn't get response. thanks for the help though.
metin
/ B300 hydraulics #4
I just bought a log splitter for my Ingersoll Rand bl370 tractor it works great at just above idle. If the tractor is not moving you can push the engine revs up at the hand throddle. If you are moving and you need more rpm's you can push the button on the loader control to tempararly put the tractor in nuteral. To raise the rpm's. IF you are talking about raising the rpm's without raising the ground speed I don't know how to do that. David.
2020 Chevrolet Tahoe SUV (A64194)
2020 Chevrolet...
2016 Toyota Tundra Ext. Cab Pickup Truck (A64556)
2016 Toyota Tundra...
JOHN DEERE 300P EXCAVATOR (A65053)
JOHN DEERE 300P...
Man Basket Boom Lift Attachment (A64553)
Man Basket Boom...
Paladin 12in Bucket w/ Teeth Excavator Attachment (A64194)
Paladin 12in...
2026 SDLANCH SDLMG1220F Galvanized Metal Livestock Shed (A64194)
2026 SDLANCH...
