B2920 WR Long 3rd function install for FEL and 3pt
   / B2920 WR Long 3rd function install for FEL and 3pt #1
marshallg22
Kubota B2920 with FEL
Hi everyone,
I received my wr long true 3rd function kit yesterday for my B2920 / LA364. So far, it seems pretty simple but I haven't started the install yet, just scouted things out. I got it from everything attachments along with "EA Compact Wicked Root Grapple 50" for my pin on FEL, as well has a set of forks also Pin on style. I figure one day later when I have a FEL with more lift capacity I can cut off the pin on brackets and weld on a SSQA plate.
Is there a way to put an extra hydraulic hookup on this now to add a hydraulic top link for the 3 point? Or a TEE of some sort?
To install the hoses to the power beyond port, do I need to remove the right wheel fender? it looks like that gray box with all the bolts/caps in it is where it will hookup.
Lastly, i'm having a hard time locating where the bulk head mounts to. It has two bolt holes but I assume I will need to find someone to help me weld it? I also assumed it would of had two bulk heads, one for on the tractor (when removing the entire FEL), and then another on the FEL for connecting the grapple to. Maybe im different from most people where I remove my FEL somewhat regularly since my 2920 is my primary lawn mower.
Any pictures of other folks who installed this, or suggestions on routing hoses, etc, would be appreciated.
Thanks!
UNUSED Grey Corrugated Polycarbonate Roof Panels (A50860)
UNUSED Grey...
Lincoln Electric Vantage 300 Welder/Generator (A49461)
Lincoln Electric...
Platform/Catwalk (A50860)
Platform/Catwalk...
2009 Ford Fusion SE Sedan (A48082)
2009 Ford Fusion...
2015 ISUZU NRR 18FT BOX TRUCK (A50505)
2015 ISUZU NRR...
2021 Spartan RZ Zero Turn Mower (A50860)
2021 Spartan RZ...
