Backhoe B2920 Rear PTO/ seat safety
   / B2920 Rear PTO/ seat safety #1
Odd Problems
Farmall,Kubota,Case
I知 new to the forum so let me know if I知 doing anything wrong.
Ok so I have a little B2920 and I知 looking for the logic of the electrical control box. I have the wiring diagrams and it just shows the connections. Reason I知 asking is running the rear PTO with seat safety systems operational does it make the engine operate like a stationary engine? Example low oil and high water temp. shut down features. I figure if they make us have these safety痴 at least they could give us some added features.
   / B2920 Rear PTO/ seat safety #2
Quite unusual to have engine guard even on large tractors, on a some it's a factory option.
   / B2920 Rear PTO/ seat safety #3
I’m not familiar with the B2920 seat safety, but the Grand L60 tractors allow unattended pto operation by tilting the seat forward before engaging the pto.
   / B2920 Rear PTO/ seat safety #4
No, it doesn't change anything other then allow it to run without an operator.
What are you trying to do?
I have a PTO generator I run in emergencies (8-12hr a day). When running the generator I’m inside the barn, so I can’t even hear the tractor running. If something were to go wrong it’s not looking good for the engine.
   / B2920 Rear PTO/ seat safety #6
You can always add a low oil shutdown, I don't think the overheat is as big of a concern but it's also possible to add if you're really concerned about it.
What would be the best plan of attack for setting up a low oil shut down? If funny how the older I get the more I think about safety.
   / B2920 Rear PTO/ seat safety #8
You can use a oil pressure switch that closes at a set pressure, if the pressure drops below that pressure then the switch opens, wire fuel shutoff solenoid into the switch. The B2920 uses a fuel solenoid that is powered to run.
Only downside is you might have a slightly extended crank so the oil pressure can build up enough to cut the fuel solenoid on.
Ok sound simple enough. I’ll probably wire a toggle switch in parallel with the new low oil switch so it only functions when I need it. Last thing I haven’t had a chance to look at the tractor but is there a good spot to tee in for the pressure switch?
   / B2920 Rear PTO/ seat safety #10
You should be able to T off the pressure sending unit, believe it's on the left side of the block near the oil filter.
I was going to suggest a bypass switch but wasn't sure how involved you wanted to get, that'll also allow you to run a higher cutoff pressure which I would prefer, since it'll only be used with the engine at operating speed.
HUSKY 135 PSI AIR COMPRESSOR (A50854)
HUSKY 135 PSI AIR...
Grady-White 17ft Fishing Boat with T/A Boat Trailer (A50324)
Grady-White 17ft...
PHENIX TECH HI POT MACHINE (A50854)
PHENIX TECH HI POT...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A49461)
2019 Generac...
2006 Pearson Quantum Fire Truck (A50323)
2006 Pearson...
