B2920 no 4wd in reverse??
   / B2920 no 4wd in reverse?? #1
ericher69
Veteran Member
Ontario Canada
2008 Kubota b2920
Used the new B2920 today with SIMS cab/heater/wiper for fresh snow removal...wow! Doesn't even break a sweat.
Now is "3wd" active in reverse also? or just forward direction?
Yes it was engaged fully but did not seem to be spinning the front tire when the rears where spinning.
ericher69
   / B2920 no 4wd in reverse?? #2
I have never paid attention, but I would have to think that 4wd (gotta use the pedal ;)) is not dependent on direction. Maybe the lever was not fully engaged? If 4wd was engaged and the rear was spinning I would think the front would be spinning or breaking.
   / B2920 no 4wd in reverse?? #3
Front spins on my B. I know cuz i'd had it a little stuck.
   / B2920 no 4wd in reverse?? #4
Yep. The front does spin in reverse rather nicely. The differential lock only locks the rear tires though. So. When you look for slipping front tire in reverse look at both sides and you will see.
   / B2920 no 4wd in reverse?? #5
I'm like ducktape, had mine stuck and know for sure the front spins.
2022 Club Car...
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A51039)
Kubota SVL65-2...
2012 Mack GU713 Tri-Axle 21Yd Ox Bodies Dump Truck (A48081)
2012 Mack GU713...
2000 Coachmen Mirada 340MB Class A Motorhome (A48082)
2000 Coachmen...
2019 Caterpillar 815K Articulated Compactor (A49461)
2019 Caterpillar...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
