B2920 mmm brackets locking in up position
   / B2920 mmm brackets locking in up position #1
gabrichter
Bronze Member
South Dakota
2012 Kubota B2920
I know when the mmm is attached that you can pin it in the up position with bracket on mmm when using the 3 point to keep it up. My question is when mmm is off the brackets are still there and rise and lower with 3 point, Would a guy just need to remove the link and secure them up with tie strap or something similar so they are not in the way?
   / B2920 mmm brackets locking in up position #2
After you get the deck off, just raise the THP to the top. Then set your mmm height control to the top position and the mmm arms will stay up.:thumbsup:
" raise the THP to the top. Then set your mmm height control to the top position"
Went our last night without manual of course. looked it over and where is the mmm height control? no levers or dials to adjust that I could see. Down under the seat there is the rod linkage with spring and double nut to limit the 3 point raise height which I adj in order to keep the chute handle on snowblower from getting too close the the seat. On that link past the spring there is a bracket with bolt in locked on that rod but wouldn't think that is the adjustement as one would want to easily adjust mmm height at times like most mowers. My NH TZ25da had height adj lever on fender.
I googled B2920 mid mount mower height adjustment and found illustration on picture. I do not have this dial knob, why would that not be there?
missing control height knob, cam assembly. The dealer must have forgot to install.
   / B2920 mmm brackets locking in up position #6
Not sure if it comes with the MMM or not? I've seen several 2920's that don't have a MMM or the knob. I don't think I've got one on mine either.
Stopped by dealer and they are ordering parts for mmm height adjustment knob and cam.
2020 John Deere 60G- Hydraulic thumb- Case Drain- Angle Blade (A50397)
2020 John Deere...
PALLET OF ARMSTRONG TILE FLOORING (A50460)
PALLET OF...
UNUSED LANDHONOR DDSL FUEL TRANSFER PUMP (A50460)
UNUSED LANDHONOR...
2015 Ford F-750 Truck, VIN # 3FRXF7FK4FV740779 (A48836)
2015 Ford F-750...
2017 Ford F-550 Bucket Truck - 4x4, Powerstroke Diesel, Versalift VST47, 52FT Reach (A50397)
2017 Ford F-550...
UNUSED Steel Diamond Plate (A50860)
UNUSED Steel...
