b2920 Front End Locker
   / b2920 Front End Locker #1
ericher69
Veteran Member
Ontario Canada
2008 Kubota b2920
Does anyone know of a manufacturer for a front end locker to get TRUE 4wd on these tractors? Something like a Detroit Locker or ARB Locker?
ericher69
The reason I ask is because I used the 3pt hitch blade today in some 5/8 minus gravel and without the diff lock (rear) it was spinning b2920...front right and Rear left. No problem once diff. lock engaged but front locker would help that much more!
   / b2920 Front End Locker #4
Sounds like you need more ballast-loaded tires and/or wheel weights on the rear and suitcase wieghts on the front if you don't have a loader. If you have a loader then scoop a bucket of rock for front ballast.
   / b2920 Front End Locker #5
The front axle isn't strong enough to have a locker in it, thats why they include one on the rear only in the little models. If you have no weight on the front it wouldn't help much anyways.
For weight in the front a 51" blower with quick hitch should provide more weight than "suitcase" weights.
And for the axle not being strong enough I find that hard to believe...
You are only talking about 29hp at the crank.
ericher69
2009 JACK COUNTY 130 BBL VACUUM  TRAILER (A50854)
2009 JACK COUNTY...
2019 Chevrolet Tahoe SUV (A48082)
2019 Chevrolet...
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A50322)
2016 Big Tex 14ft...
1274 (A50490)
1274 (A50490)
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A51222)
2019 INTERNATIONAL...
2015 CAT CT660 T/A Cab and Chassis Truck (A48081)
2015 CAT CT660 T/A...
