B2910 Set Pin Chains
/ B2910 Set Pin Chains #1
Elkoboy
Elko, MN
Kubota B2910
Yah, I know this doesn't hold a candle to most of the projects here but it's simple and it works for me so I thought I'd show it off.
I love the 3 point telescopic stabilizers on my Kubota B2910. However, I never seem to have a convenient place to put the set-pins and hairpin cotters that are used in them when I'm attaching and removing implements.
Kubota has a place to put the lynch pins when they're not being used; I wish they would have done the same for the set-pins...
In the past they've ended up in my pocket where I have to dig them out when I need them again. And if I drop a hairpin in the weeds they're hard to find.
So I got four sections of chains, a chain link and some swivel clips and attached a chain to the split ring on the set-pins with a quick-link and swivel clip at the other end, and another short section from the split ring on the set-pin to the hairpin cotters so they're attached together. The swivel clip attaches to the split ring on the 3 point lift arm links.
Now, nothing gets dropped on the ground or lost! I can just drop the set-pins and hairpins yet they stay attached, and I just grab the chain to pull them up again. And the short section of chain makes it easy to pull the hairpin cotter out of the set-pin as well.
Close up
/ B2910 Set Pin Chains #3
Seems like a good application of the K.I.S.S. principal /w3tcompact/icons/laugh.gif Wish I had the telescoping lower arms, I have the turn buckle type which are a minor pain (until I put on a quick hitch, now it's a moot point).
/ B2910 Set Pin Chains #4
Yes, very real problem. I did the same thing on mine but attached the chain to the lower pin on the lift links rather than the upper.
I like your approach better. I found that when brush hogging the branches etc would rip the chains off. Your approach leaves less hanging below the water line. I'll try it.
Kubota ZD21 (A64912)
3146 (A63117)
3146 (A63117)
2018 MACK CXU (PINNACLE) (A67714)
2018 MACK CXU...
2022 John Deere 5100E (A64911)
2022 John Deere...
2014 CATERPILLAR 320EL RR EXCAVATOR (A65056)
2014 CATERPILLAR...
2003 Sterling L7500 S/A Day Cab Truck Tractor (A66736)
2003 Sterling...
