Mowing B2910 Mid Mount Mower
   / B2910 Mid Mount Mower #1
dlockh4258
Lexington Kentucky
Kubota B2910
How much wider is the 72Inch MMM than the tires. Someone said it is very easy to attach and detach the MMM. I also read where someone said you cound drive over top of it and that seems impossible to me unless the tires are wider than the mower. For those of you who have the 72inch MMM, please explain how to attach and detach this mower.
Thanks,
   / B2910 Mid Mount Mower #2
These mower are built to withstand the weight of the front end of the tractor.You literally drive up and over the deck to attach and or remove it.
You have to raise the gauge wheels up as far as they go,place a couple of 1x blocks under the lip of the deck where the front tires will be rolling over the deck.Let the deck down(should be resting on the 1x blocks) and unhook all the linkage and P.T.O. shaft,raise the linkage back up out of the way,put a couple of blocks at the edge of the deck to help get tractor started up and over the deck,(4-W.D.)and simply back up over the deck itself.
Reverse this procedure to re-install it.Very simple,I've done it a 1,000 times with no problems.
KJ 7'x20' Metal Gate (Deer) (A50121)
KJ 7'x20' Metal...
Year-A-Round 550 Gravity Wagon (A50774)
Year-A-Round 550...
2022 Case IH Steiger 470HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52577)
2013 UTILITY VS2RA...
2014 Infiniti QX60 SUV (A50324)
2014 Infiniti QX60...
STORAGE FEES (A52577)
