B2910 Draw Bar Attachment ??
   / B2910 Draw Bar Attachment ?? #1
PowerMax
Southeastern Ohio
Kubota B2910
Is there a device made that holds the draw bar in place (not allowing it to spin or turn) so that you can pull a trailer around. I think something could be made (2 pieces of flat bar), but I'm not sure where it would attach to the lower 3-point arms. No sense in re-inventing the wheel. Thanks.
Jeff
   / B2910 Draw Bar Attachment ?? #2
PowerMax
We carry the 'draw bar lock' in our parts department. I believe they are available from TISCO or BECKNELL. Hope this helps.
Lewis
   / B2910 Draw Bar Attachment ?? #3
Here is one style
I got mine on ebay, might check there. But keep in mind, it will NOT work on all lift arms.
   / B2910 Draw Bar Attachment ?? #5
TSC sells one, but it is not compatible with the extendable arms on the B2910. The mechanism for releasing the arms gets in the way of attaching the draw bar lock to the arms. If you have a way to make them, that would probably be the easiest. If you find something that will work with the 2910's design, please let us know.
GOOD LUCK /forums/images/graemlins/smile.gif
JOHN DEERE 437E KNUCKLE BOOM LOADER (A52705)
JOHN DEERE 437E...
TEREX RT665 MOBILE CABLE CRANE (A51406)
TEREX RT665 MOBILE...
ELECTRIC GOLF CART (A53843)
ELECTRIC GOLF CART...
JOHN DEERE/UNVERFERTH 1700/330 LOT NUMBER 13 (A53084)
JOHN...
2022 Gravely Pro-Turn 600 Zero-Turn Mower with 72-Inch X-Factor 3 Deck (A53473)
2022 Gravely...
CATALOG IS A GUIDE ONLY!! (A50775)
CATALOG IS A GUIDE...
